Scalers...explain please...
Discussion in 'Projectors, Screens & Video Processors' started by Roohster, Sep 16, 2004.
  1. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    I'm looking to improve the image from my SKY+ box and wonder if a decent scaler would help?
    The setup I have is:
    Panasonic PW3 42" Plasma
    SKY+ digibox, connected via s-video, through Arcam AVR200 amp at the moment.
    Arcam DV88plus, connected direct to monitor via component.
    Obviously, as Im using the component input on the Panny for my DVD, I cant utilise the monitors RGB capability for my SKY signal.
    I tried a simple RGB - VGA converter, but the results weren't too good.
    Any suggestions?
  2. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    ....anyone?.... :lease:
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  4. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    No, the next question is, how will it work?
    Does the scaler have an RGB input?
    What output does it have to my plasma?
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Depends on the scaler. The ones I distribute have RGBcompositesync inputs. They output RGBHV, RGsB, YPrPb via analogue or DVI to a DVI or HDMI input. They have advanced oversampling analogue to digital convertors to capture the incoming signal where they do the processing in the digital domain. Film and video source material is recognised and processed using the most appropriate algorithms before being scaled and output as required.
    You could use a SCART to 4phono lead to one input and a set of component leads from your DVD player to another. Each input can be set to auto sense incoming signal type and load up specific input memories which have been tweaked specifically for your sources. This allows independany setting of contrast/brightess/colour/etc as well as input size/position (overscan) per signal type per input. They also do a few other things that are a bt complex to get in to right now.
    I'd have a chat with some of the dealers on here. Joe at The Media Factory, Liam at Progressive-AV and MAW at The Bigger Picture all have experience with plasma, freeview/Sky and scalers.
    Gordon
  6. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    Thanks Gordon.
    What do you think would be the minimum I could spend and still get decent results?
    I'm already happy with the picture from my DVD via component,
    all I really want to do is get a decent pic from my digibox.
    I dont want to have to use loads of converters, so something that will accept RGB from SKY and output VGA would be ideal.
    Also, I want something that is simple (ish) to use!
  7. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    Any suggestions?
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Look at products from Lumagen and DVDo (Anchor Bay) and Cinemateq. I distribute Lumagen but the dealers I mention do combinations of all these and should give you some good advice.
    Gordon
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    roohster2
    To install a decent quality Video Processor into you system is going to cost the best part of £1K if you want Deinterlacing and Scaling.
    Though your happy with your DVD players output a Lumagen VisionDVI (£800.00) uses a higher quality Deinterlacer than your DVD player (in fact it uses the same one Arcam use in the more upmarket FMJ products) and you'll see benefits with even that source if you install the Video Processor.
    As Gordon has indicated you can Input RGB+Composite Sync from your Digibox directly to the Video Processor so no additional adapters or converters are required.
    Another advantage of installing the Video Processor is the range and finesse of the video signal adjustments possible - the Lumagen menu's are much more refined and detailed than you get on your display; we can often see one or two additional steps of detail in signal test patterns using the Lumagen over a direct connection to the display and using multiple memory banks in the Lumagen you can have the Video Processor auto detect PAL and NTSC signals from your DVD player and pre load optimum settings for each signal type (we can also use the Lumagen to give you Daytime and Night time settings if you have a lot of ambient light in your viewing room)
    None of the Video Processors are exactly - simple to use - they are extremely versatile and programmable and whilst a dealer can pre set them to make them compatible with your display you'll get the best out of the Video Processor after lots of fiddling or have your dealer install the Processor and ISF calibrate your video system (£250).
    Any questions please shout.
    Joe
  10. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    Thanks for that Joe!
    It's all a bit clearer to me now.
    Now, all I've got to do is find a grand for a Lumagen...
    By the way, does anyone have any idea what sortof outputs the forthcoming SKY HiDef box is likely to have?
    Component? HDMI?
  11. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hopefully both of those, and VGA would be nice too (but unlikely).
    Steve
  12. Roohster
    Roohster
    Jul 1, 2004
    3,875
    3
    Derbyshire
    +3,912
    Just had a look at this on the IVOJO site,and it doesn't appear to have RGB inputs:
    Inputs
    Component 2 * 3 RCA
    S-Video 2
    Composite 2
    DVI-I 2 (HDCP)
    SDI Optional * 2
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    might be able to run it over DVi-I
  14. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    The Component inputs are configureable for RGBS where the sync is taken from the composite input beside it. On the bigger Pro unit the inputs are even more configureable.
    Gordon
    component video signals are many and various....YPrPb, YCrCb, RGsB, RGBS, RGBHV, YC......
