Scaler & VPH D50HTU..
Discussion in 'Projectors, Screens & Video Processors' started by museumsteve, Aug 5, 2002.
Thread Status:
Not open for further replies.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    7,993
    4
    Nth Hampshire
    +1,105
    would I need one..??
    Basically I may have the opportunity to get the above Sony, if I did would I still need to use a scaler.??
    I'm a total virgin when it comes to CRT but could ditch my Panny PTAE1000 in favour of this if the feedback is positive enough..
    Thanks in advance..
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,216
    +3,071
    Steve:
    I'd suggest a minimum of an Iscan for use with this device. Ideally a scaler will get the best from it but you can get away with a decent de-interlacer like Iscan or Omega1.
    On a 16:9 screen you are probably looking at trying to get 600P ish out of it. A de-interlacer will get you 576P from PAL and 480P from NTSC.
    If you need more info just ask.
    Gordon
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    If it truely is a D50 HTU it will have a built in line doubler any how. the Iscan will give better results too.
    A really well set up D50 will resolve line tripling too. but not Quadrupled.
Thread Status:
