Scaler to match 1368 x 768 LCD TV?
Discussion in 'Projectors, Screens & Video Processors' started by dogastus, Apr 5, 2005.
  1. dogastus
    dogastus
    Jan 24, 2003
    204
    Newbury, England
    +5
    I'm looking for suggestions of a suitable scaler for feeding the DVI input of my Sharp 26" LCD TV at it's native resolution of 1368 X 768. I have see the set working superbly with my PC so I know what it is capable of. I primarily want it to accept an RGB feed from my DTTV set top box and it would be nice if it could take the DVI o/p from my PC.
    The Lumagen DVI scaler looks like it will do the job if it can match the o/p resolution I want? It also has enough extra inputs to cope with anything I am likely to want to use in the (near) future.
    Are there any other units I should be considering?
    Any local reps I could contact (Newbury, Berks)?
    Thanks.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    Dogastsu
    Any of the Lumagen Vision video processors will do what you require - though worth noting that your DVI Input may react badly to Native Rate from a 'Video' source; often these PC Inputs reprocess the incoming signal and undertake Frame Rate conversion which produces odd artefacts if your trying to run 1366x768 at 50 or 60Hz.
    Its worth a Home Trial first to ensure everything will work as required.
    Best regards
    Joe
  3. Vince M
    Vince M
    Nov 2, 2004
    473
    19
    Lagoa
    The HD+ ALSO DOES 1366 X 768. :thumbsup:
  4. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
