Scaler Recommnendation(s)
albrecht
I am looking to get some input regarding recommendations for scalers with a max price of EUR 1000,00. I will use the scaler for my future PHD8(50inch)
Any recommendations????
best wishes
matthias
Welwynnick
Difficult to say whether it is worth it, as the PHD8 video processing is relatively good. The best option would probably be an iScan HD+ or Lumagen VisionDVI,but both are stretching your budget. Many people here would probably say that a TH-50PHD8 deserves better, and you ought to consider a Vision HDP, especially if you want to consider using high definition broacast and stored sources in the future.
regards, Nick
