scaler rca to yuv component cable needed
Discussion in 'Cables & Switches' started by nisnos, Nov 1, 2005.
  1. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    hi
    i need the cable that connects my cinemateq picture optimiser rca to the YUV component port on my DLP tv.
    i have no idea where to get one could you please assist.
    many thanks
  2. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    sorry meant vga to yuv component (Y Pb Pr)
  3. Light_User
    Light_User
    Feb 10, 2005
    305
    +6
    I'm looking at an advert for cableuniverse right above your post - just click on the banner ...
    Also AV Sales + a few other sponsors of this site may have what you are looking for.
    Otherwise, just do a search on google or yahoo.
    I'm sorry that I cannot be more specific, but I hope that this helps you.
    Good luck.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    Hello nisnos
    What length of cable are you after?
    Best regards
    Joe
  5. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    hi joe
    it sits below the tv so i guess 1 - 1.5 meters would do it
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    Hello nisnos
    VanDamme Red Series is a very decent and 'relatively' inexpensive option for you - a 1.5m HD15(VGA) to 3RCA cable will cost you around £50.00.
    A lot of the cost in a short cable is in the labour costs so don't skimp on cable length if you think you may require a longer cable run at a later date - an extra meter of cable is only going to add around £5.00 to the overall cost.
    I'd also suggest you may want to consider an HD15(VGA) to 5RCA cable - that way its dual purpose for YUV or RGBHV; just in case you ever swap your TV for one with RGBHV inputs!
    Again minimal cost difference between a 3RCA or 5RCA cable.
    Best regards
    Joe
  7. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    hi joe could you pm me with the price for the 5 output one and based on 2m then im safe.
    many thanks
    david
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    Hello nisnos
    You have a PM.
    Best regards
    Joe
  9. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    many thanks
