scaler problems - DVDO HD+
Discussion in 'Projectors, Screens & Video Processors' started by scouse258, Aug 26, 2005.
  1. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    Thanks for reading
    BENQ PE8700, Arcam DV79 and an upgrade - DVDO HD+ scaler
    Being a typical cinema buff im always on the lookout for upgrades but the latest has casued me a problem
    before i upgraded my scaler, the scaler happily "passed through" the digital image from the dvd player to the projector - hdmi to dvi lead into the scaler, dvi cable out of scaler into the projector - no probs.
    After the upgrade though i can not get an image.
    The problem seems to be HDCP - when i turn on the dvd player the arcam screensaver pops up and i can play non HDCP discs but putting in a normal dvd disc and it wont show the pic
    i cant understand the problem as when i play the dvd player straight to the projector it works fine suggesting the both the player and projector are HDCP compliant
    why wont the projector take the pic from the scaler then?
    is it a scaler thing or a projector thing?
    dont suppose i will get an answer but it is worth a try as its taking ages to get a response via DVDO,
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    scouse258
    Has your dealer set the iScanHD+ to a resolution/refresh that matches your Projector?
    Joe
  3. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    further to the above reply, as i can see pictures via component it would suggest it is the HDCP protocol which is the problem.
    ALSO - DVDO were really quick with a response - it would seem my original email did not get received
    JVB Digital Holland upgraded the scaler for me but forgot to load the new software on
    they have offered to do it for me if i send it back to them again but this will cost me £50 in postage
    DVDO USA have confirmed a problem exists but it mainly is on panasonic units and they are working on a new software release
    i still have suspicions that the projector doesnt like HDCP signal via its DVI port but BENQ have stated it is HDCP compliant which points the finger back to the scaler
    Anyhow - im going to upgrade the software via their online download site so fingers crossed
    im stuck with component in at the moment so i am worse off after having an upgrade as atleast i could pass through a digital signal
    i will update the site if the upgrade works
  4. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    Well - i did the upgrade - remarkably easy - but it hasnt sorted out the problem - still cant get a picture - pass through or otherwise via digital in from my DVD player
    it will play non HDCP material no problem
    anyone else had this problem
    waiting for a reply from tim at DVDO at moment
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    Hello scouse258
    Didn't fully follow your original post - I take it you've had an HD and now its an HD+!
    Certainly sounds like a handshaking problem - possibly to do with older DVI circuitry talking to newer DVI circuitry; have you tired setting the Arcam to output an Interlaced signal via its HDMI output?
    Best regards
    Joe
  6. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    Unfortunately on the Arcam DV79 there is no way to switch progressive scan off on HDMI output
    Also since then the analogue output has given up on me!! - i get green pictures via all sources now an a message ERR - EC00 - 761 -025B coming up - im not exactly a good advert for JVB Holland (who did the upgrade) or DVDO am i?
    Both the gents are tring to help me Jan from JVB even phones me saturday(and what i have forgot in my first link was that DVDO USA are 9hrs behind us - silly me) but i now have both my dvd players and sky hooked directly up to the projector as i am also suffering from motion jerkyness when watching football
    previously i had this problem at all upscaled resolutions but i simply turned to 576P and this sorted the problem out - now i have jerkyness at that resolution - since the upgrade!
    this problem seems apparant to all quick motion sport
    i wish i hadnt upgraded to be honest - and perhaps bought a Denon 3910 to scale my dvd pics instead
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,200
    +3,031
    Actually there is a way to turn progressive scan off on the ARCAM...Not only that you can decide whether to output the 480i/576i as component or RGB digital video data....
    Turn Force DVI to OFF,
    Turn Priority to Analogue
    Turn Progressive to OFF.
    Bingo.....
    Gordon
    Gordon
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    Gordon - you beat me to it :)
    Scouse258 - one of the (many) great features of the Arcam DiVA DV79 and FMJ DV29 is the ability to Output an Interlaced YUV or RGB signal via HDMI; its as close as you'll get to not having to worry about the extra cost and complexity of SDI.
    Stick with the system you have - once its working its potentially way better than an up-scaling Denon :)
    Best regards
    Joe
  9. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    All
    please note that i withdraw any reservations i may have about either company as the customer service is second to none
    Thanks to Tim in DVDO.com USA - i have a fully working scaler.
    Apparantly it is a "hand-shake" problem between the projector and scaler not necessarily the scalers fault
    He sent a patch (which is normally used on panasonic projectors that have shown this problem) making the projector accept images from the player and scale them too
    the main problem with all this is the time difference between UK and USA which delayed things a little.
    Anyone wanting DVD or scaler upgrades please checkout www.jvbdigital.com
    as they do some exceptional stuff with your kit - Jan was very friendly and helpful
    The green screen was caused by the software update which reset my settings to factory (which was stated on the download page) - it was fixed by typing in my new settings - bingo
    as for the motion jerkyness - not tested this yet but im advised that it could be due to the framerate not being locked which again is a setting thing
    although i have not tested this - they have come up trumps on the other stuff so fingers crossed
    Tim/Jan - i have been a bit of a pain but i would now love to upgrade to the VP30 in the future
    5 stars to you both
    chris
