Scaler for anamorphic stretch?
Discussion in 'Projectors, Screens & Video Processors' started by celtic13, Feb 6, 2009.
  1. celtic13
    celtic13
    Dec 16, 2002
    689
    96
    Belfast, Ireland
    +509
    Hi Guys
    I am about to pull the trigger on a new projector - probably a sony vw10. At present i don't have the horizontal space for a cih set up but more than likely will in a year or so time.
    If I buy the projector now is there a scaler that will allow me to do a vertical stretch with anamorphic lens at a later date?
    Many thanks
    Paul
  2. Mad Monk
    Mad Monk
    Feb 12, 2007
    1,012
    London
    +110
    I use a Lumagen HDQ with an Isco II with great results although you could possibly use a cheaper video processor if you only need the 2.35:1 functionality.
  3. celtic13
    celtic13
    Dec 16, 2002
    689
    96
    Belfast, Ireland
    +509
    Many thanks MK, that Isco must be a sight to see! What pj do you use and what size is your scope screen?
    P
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    DVDO Edge has some configurability for this, but you can't beat the Lumagen for being able to program up several different input/output configurations and profiles.
  5. Mad Monk
    Mad Monk
    Feb 12, 2007
    1,012
    London
    +110
    I'm using the IscoII with a Sharp 12000 MkII. The lens on the PJ is very sharp and it works very nicely with the Isco lens. Any anamorphic lens that you use will soften the picture a tad (unless it's a real high end lens), that's why I think the Sharp is just a good match for for the Isco.
    I'm not too up to date on the newer PJ's but consider a DLP PJ if it gives a slightly sharper picture, I did see the Infocus IN80 and it looked very very nice indeed.
    I've experimented with curved screens from 8' to 10' wide and am currently trying to light up a 11' wide screen with a little difficulty. More lumens needed lol!
    MK
  6. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    My elderly Iscan HD will do what you need as well as any PJ with Letterbox (LBX) AR. Its not an uncommon feature IMO.
  7. celtic13
    celtic13
    Dec 16, 2002
    689
    96
    Belfast, Ireland
    +509
    I just received the projector yesterday and eventually will go down the cih route. At the moment the room restricts the width but that could change!:devil:
    Many thanks
    P
