Quantcast
Scaler for AE200
T
Truecelt
Hi All,
After reading this months article in HCC on scalers, Im now wondering should I invest in one for my Panny ae200. Have any of you any advice on whether this improved the picture on this pj, and if so which reasonable priced model is best suited Thanks
:rolleyes:
K
Kramer
Nothing wrong with the AE200 but given its place in the "food chain", entry level LCD, I'd suggest saving for your next (inevitable ;)) upgrade rather than spending megabucks on a scaler.
You could also use a PC (HCPC) to maximise PQ on a budget.
:smoke:
gizlaroc
I would definitely second that.
Why spend £800+ on a scaler when you could put that towards a PJ, that will give you a far bigger gain.
