Scaler/Doubler for my plasma
Discussion in 'Projectors, Screens & Video Processors' started by kevshed, Jul 21, 2003.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,223
    48
    bournemouth
    +85
    Hi guys..
    quick question..
    I am currently feeding my NTL Digital box into a JSim RGB->VGA converter for use on my panny W3 (yes yes i know its dated now..:p) plasma. All of my other sources (DVD, Consoles etc) deliver progressive, so thats fine, but the picture from NTL, although i've tolerated it, could be a lot better.
    So.. my question for the group is...
    Is it worth investing in an IScan type product to increase the picture quality of my NTL.. or am i likely not to see a difference?
    What else could i do to improve things.. without spending a small orune?
    Advice comments on what others have done are welcome..
    Cheers,
    Kev
  2. jmack
    jmack
    i have just last week bought a iscan ultra for my toshiba 42wp16(panny 4 clone)
    and was thinking is this any differance till i watched the liverpool football match and the grand prix this weekend alot less jaggies and smoother lines. it does add a bit of lip sync though and every not and then sort of judders but only every now and then.
    in all vey happy with it.
    using ntl digital and a js tech component conveter and a vanndame vga lead.
    ps using the interlased output of my progressive philips 962sa dvd player into it as i think its better than the on board progressive on the dvd player.
    got mine for £350 deliverd off ebay.
    there is a iscan pro on there for £150 at moment
  3. kevshed
    kevshed
    Oct 30, 2002
    1,223
    48
    bournemouth
    +85
    thanks... i've seen the auction will keep an eye on it.
    Whats the difference between the pro and ultra?
  4. jmack
    jmack
    ultra has the chroma delay funtion/vga pass through /dvi output/ 2 component imputs/2 composite/2 s-video. and there proberly more funtions. iscan pro does not have all these things
  5. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    If you're looking to buy an Iscan there's an Iscan Ultra on eBay at them moment, alternatively my Extron is also up there.
    I was going to sell on the forum but just couldn't work out what was a fair price to ask.
    Mark.
