Scaler Does improve Sky
Discussion in 'Projectors, Screens & Video Processors' started by raydundas@bluey, Dec 24, 2004.
  1. raydundas@bluey
    raydundas@bluey
    I have seen a few posts, asking whether a scaler can improve Sky to any great extent. Well, Gordon came and installed my Lumagen DVI scaler yesterday and it makes a great difference. I did pay to also have it properly setup and it was well worth it. Smoother, more filmic image, less digital noise and really just a pleasure to watch. I am using it with a Pioneer 50 MXE1. DVD has also improved and Finding Nemo is looking nothing short of stunning.
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Nice one mate :smashin:
    Did you get Gordon to calibrate it too while he was there ?
    If you don't mind me asking what timing settings are you running your Lumagen at ? I assume your using FRC mode 2 and DVI output.
    Cheers, Lee
  3. raydundas@bluey
    raydundas@bluey
    God yes, or I would have been lost. I got the full Video calibration. Don't know the timings Gordon used. Said they were Pioneers recommended timings. With Christmas, not had a chance to delve into lumagen menu and note down any timing info. Do not know if the Pioneer timings are regarded as trade secrets, for an incentive to use a proffessional installer, or if Gordon will give them to you. You would need to ask. Yes I had the set using FRC2 and am using DVI from Lumagen to Plasma.
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    In that case he probably got them from me as I asked Pioneer what the optimal timings were and they sent me a few documents one listing all the various mode and timings...just wondered if he used them or not...or if he'd found something different/better...have you joined the official forum yet ? I posted a bit of info on there about it.
    Reason I asked is that I'm having a spot of trouble with smearing of skin tones - on faces especially - with both DVD and Sky+. Have you noticed this at all ?
    Been speaking with another 50MXE1/Lumagen owner who has also had his setup calibrated by G and he has not noticed it so I am hoping when I get mine calibrated it will clear up.
    Gordon is due to pop by again in early Feb as he set mine up for my PJ but I've since added the MXE1.
    Anyway...glad your pleased with the results.
    Cheers, Lee
    PS: Happy Xmas
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    Merry Christmas....just off to meet rest of family for the whole 9 yards but had to pop over to the forum to see what was what today...
    I did use the timings Lee provided from Pioneer. I am going back to Ray's to check a size issue he had after I left. Not sure when though.....if I get the chance I'll try to check the issue you have seen Lee.
    Gordon
  6. Scott KL
    Scott KL
    Dec 9, 2004
    14
    Lee,
    I have a 505-HDE with a 868i DVD player connected via HDMI and satellite receiver connected via S-video. I am about to get a test unit iScan HD+ installed [dealer waiting on HDMI-DVI cables] to see the difference in picture quality for both satellite and DVD feeds and will post my findings in the New Year.
    I am putting faith into the dealer to set up the iScan HD+ correctly. I will have a calibration disc on standby but was wondering whether the documents listing the optimal timings of the pioneer plasmas would also apply to the iScan unit as well as the Lumagen. I assume these timings etc. are to do with frame rate conversion, etc. I am still a little lost when it comes to video processing so would appreciate any help from the experts to get the most out of my system. Are these documents readily available from Pioneer, where is the best place to get hold of these?
    One other quick question (to all); the iScan dealer says I do not need to connect the satellite analogue audio feed through the iScan unit to deal with potential lip sync as the iScan can deal with this even if audio is fed direct from STB to amplifier. I thought the iScan HD+ put a delay in the audio due to the extra video processing?
    Appreciate your feedback.
    Scott
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Iscan HD (not played with HD+) can adjust the timing ie delay the DIGITAL audio feed for a source i could not delay an analogue feed from SAT box to AMP so i think he (OR I) may have crossed wires...........
  8. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Hi Scott,
    I'm afraid that the timings I have are specifically for the MXE1 range of plasmas and were useful as it gave us the correct timings to get a 1:1 pixel-mapped output from the Lumagen using the official timing data. I've not played with an iScan but the timings should work fine with it as well.
    With the 505HDE your best bet is to set the iScan to output 720p at 50Hz for PAL and 59.94/60Hz for NTSC as you are not able to send the panel it's native resolution of 1280x768 directly so you'll have to rely on the panel to scale the image from 1280x720 to 1280x768…not ideal but not the end of the world either.
    Cheers, Lee
  9. sekrof
    sekrof
    Dec 14, 2004
    9
    The HD+ will automatically delay the input audio to match the video processing delay. The manuals don't state that this is specific to either digital or analogue (audio) inputs.
    I also don't believe it would slow down an audio source, if that source was not routed via the HD+ :)
    Hope this helps.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sekrof can you delay analogue audio in HD+ was sure it was only for digital inputs on HD
  11. sekrof
    sekrof
    Dec 14, 2004
    9
    Thanks for the clarification Horny.
    Best wishes.
  12. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Doesn't everyone on this formum have Sky+ or if not Sony Digiboxes? (Both with DIGITAL sound output? ;))
    StooMonster
  13. sekrof
    sekrof
    Dec 14, 2004
    9
    Not me :) I have to wait until Jan 17th until the Sky people can climb a ladder & plug me up for Sky+. At present I'm stuck with plain SkyDigitial and a very old Panasonic digibox (groan).
