Scaled-up vs scaled-down
Discussion in 'TVs' started by pingu, Nov 30, 2004.
  1. pingu
    pingu
    Nov 30, 2004
    434
    28
    Berkshire
    +28
    Hi all,
    First some assumptions that I hope are correct:
    1) Future HD broadcasts in the UK will be made in either 720p or 1080i and this can be on a per programme / channel basis.
    2) Blu-ray / HD-DVD discs can contain either 720p or 1080i content (or standard def.) at the choice of the content supplier / distributor.
    So, given that the HD display I will buy will be either a 720 or 1080 line one that supports both formats (and will be perfect for the corresponding format), is it better to watch 720p scaled up on a 1080 line display or 1080i scaled down on a 720 line display?
    I guess the ratio of 720p to 1080i content produced is a major factor as is the extra premium of 1080 line displays, but I'm just trying to get a feel for if there is a noticable difference - i.e., will buying a 720 line display mean missing out on the full splendor of 1080i content or vice versa?
    Cheers,
    Steve.
  2. Rimmer
    Rimmer
    You're assumptions are largely correct, although HD-DVD/Blu-ray is also likely to support 1080p at 24/25/30 frames per second.
    1280 x 720 resolution TVs are actually quite rare so unless you buy a DLP RPTV up and downscaling is always going to happen. LCDs are typically 1280 x 768 or 1366 x 768 resolution. 1080p displays exist but are expensive and you'd be lucky to find one in this country at the moment.
    If you do go for a 1080p model when they become available, as long as the scaler is good then 720p pictures should not look worse at 1080p; they make even look better. A 1080p display would allow you to see 1080p HD-DVD content without any scaling.
