Dave_Gregory
Established Member
Hi all,
I have had to have scaffold put up around the chimney as i had a leak
The boards were about a foot over the LNB so obviously no signal which was to be expected. When the work was done I went up and removed the boards, but I still have no signal so I am guessing the dish was knocked when they put the scaffold up
Problem is I need to leave the scaffold up at the moment as there is another leak on another part of the roof so cant take it down until all works are finished and proven.
My problem is that I am loath to call out an engineer to fix the alignment as they could easily knock it again when they remove the scaffold, and I am back to square one, so is there anyway I can just move the LNB a little at a time with the wife watching the TV to see when I am on the right plane? or should I buy a sat finder?
Its been about 3 weeks now and the wife and kids are starting to go stir crazy as freeview just isnt cutting it, and thats before I mention the £52 i am wasting a month !!!
cheers
Dave
cheers
Dave
