SC-LX82 12v trigger question?
bobbymax
For the life of me I cannot figure how to set the trigger up:(
Have run the cable from amp (top jack outlet) to my RXW12 sub and can't set it up as per manual (it's all Greek to me:rolleyes:)
on page 47/48 it says to select Main zone 2, Zone 3 or off I didn't know that the Zones came into it......... totally :confused:
Has anyone else set the 12v triggers or have a good understanding of how this is set-up/works?:lease:
lunarwolf
you need to go to set-up menu select each input and activate the 12v trigger for each input (BD, DVD etc...) that will require it
it should be similar to my SC-lx71 -> home menu / system set-up / input setup
bobbymax
cheers Lunarwolf, I did go into the set-up procedure, but it asked to assign to Z2or 3 and that's what confused me :(
Also it didn't appear to have a trigger assignment for a subwoofer.
I'll have a play around again later.
lunarwolf
that should not matter, if the 12v trigger jack is connected to the subwoofer and let's say you set it to on when on BD input, everytime you select BD the subwoofer will be triggered by the 12v jack. if you do that for all inputs then the subwoofer will be triggered for all selected inputs ;)
bobbymax
Thanks again. That's me brain put right just to set it up now, shouldn't be a prob :thumbsup:
