SB Live 7.1 24Bit Sound Card
Discussion in 'Computer Components' started by chuckalicious, Sep 21, 2005.
  1. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    Quick question.
    Does anyone use a Sound Blaster Live 7.1 24Bit sound card in their PC?
    My question is, the card has a SPDIF output, in the form of a 3.5mm socket. The Sound Blaster site says
    * Supports SPDIF Out for Stereo Digital Speaker/ connection with Creative Digital I/O Module (sold separately)
    Now I thought I'd be able to just use a 3.5mm to Coax/RCA converter and use my standard coax digital cable to my AV amp. Is that correct? I don't want to out and buy this card only to find I can't use it with my coax input on my amp.
  2. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    You need a mono 3.5mm to phono jack the the one here
  3. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    I thought so!
    You're a star. Think I'll pop out and buy one of those today :)
  4. bradleyjonesuk
    bradleyjonesuk
    I have that soundcard and the same setup as you want . It all works apart from with about 10% of songs I get a bad hissing from the speakers!! I posted this in the forum aswell today.
    Also If you want cables I recommend the following website: www.tvcables.co.uk. They are very very helpful, cheap and delivery costs are very good too.
    The part you want is :http://www.tvcables.co.uk/cgi-bin/tvcables/AD011.html . Its only £1.50 and the postage/packing will probably only be about £1 or less.
    I also got a 10m digital coaxial cable for £6.
    Brad
  5. chuckalicious
    chuckalicious
    Sep 15, 2004
    247
    +4
    Reason I need a converter is because I already have a coax cable (about £50) which I used with my DVD player to my amp, so no point in wasting it :)
    That is a very cheap site though, will be bookmarking that one.
