Saw a 32" Hitachi in action.
Discussion in 'Plasma TVs Forum' started by raven219, May 12, 2003.
  1. raven219
    raven219
    Mar 5, 2001
    544
    East Anglia (well someone has to live there!)
    +19
    Had a quick look at the Hitachi CL32PD3000 over the weekend. The shop had it showing the football on Sky. The picture was not that great (espically compared to the CRTs) but then I learnt that they had wired it via a composite lead. Mind you when he changed it over to Kiss (or some dance music channel) the picture was stunning.
    Q - Because the hitachi has the media box, would one of those infamous RGB to VGA convertors still do the business?
    Raven
  2. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    The Hitachi CL32/42PD3000 are both supplied with a AV media box with 3 scarts (2 RGB), component, S video and PC inputs so most equipment can be connected directly. The PQ is excellent.
    You cannot use a RGB to VGA convertor as the input accepts a minimum input frequency of 24KHz
  3. raven219
    raven219
    Mar 5, 2001
    544
    +19
    So that means that any Sky connections would have to be done with a RGB Scart then? I had read that people had got a better picture on plasmas by using the RGB to VGA gubbins.
    Raven
  4. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    The main purpose for the convertors is to allow coonections between AV equipment with RGB scart outputs and screens and projectors with incompatable inputs like PC style RGB and component inputs.
    You could buy a RGB to Component convertor but I would doubt you would do much to improve Sky's picture quality over the direct connection which on my screen is excellent given the variable output of digital satelite channels. Perhaps an expert could comment?
