Saving radio stations on a Sony cdx-ca700
Discussion in 'Video Streaming Boxes & Services' started by michaelm, Mar 15, 2003.
  1. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    My wife's nephew has just upgraded his Sony cdx-ca700 to a JVC unit, and I got the Sony.
    However, after fitting the unit perfectly first time in about 5 minutes, I cannot find how to save the radio stations.
    Can anyone help me with this?
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Is it the case that you are unsure how to save stations or is the unit not saving them after switching off the ignition ? If it's the latter you may need to swap the position of the switched and unswitched supplies.
  3. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    I tried that, the 12v supplies WERE in the wrong positions for my car, and other memory functions like EQ, audio, function, clock etc were not being saved, so I switched them. But I cannot tune to a station and then save it to a memory position, and that is mostly what I want to do.
    Smashing piece of kit though. :D
  4. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Apologies if this is "teaching how to suck eggs" but from experience with Sony head units, most of them let you "save" a station in the following manner:
    1. Switch to the preset bank you want to save under (FM1, FM2 etc).
    2. Manually tune to the desired station.
    3. Press and hold the preset button where you want the station saved. After a couple of seconds the display should update and the station should now be saved on that preset.
    4. Check by tuning to another station, then press the preset you just used. Hopefully your "saved" station should now be selected.
    Hope this is of some help.
  5. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Cheers for the reply AOD. Fortunately I found a website that allows pdf downloads of installation and instruction manuals for this head unit and several others.
    The correct method of storing station presets is as follows:
    1. Select preset bank
    2. Tune to a station
    3. Press the preset number on the remote for a few seconds
    Just as well I had the remote as well then. :D
  6. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Oh well, I was close. :blush:
    Not being au-fait with that particular head unit, does it not have any preset buttons on the fascia, or are those only present on the remote?
  7. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Remote only. I wasn't having a pop at you, btw. Sorry if you thought I was.
  8. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Don't worry, I didn't think you were having a pop.
    I must say, I'd prefer to have the option of fascia buttons (in case the remote ends up under the seat) but there we are. The onward march of progress, eh?
