saving in windows movie maker
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by juliana, Sep 2, 2005.
  1. juliana
    juliana
    I edited my video and when I try saving it on my computer I always get the same message: the video can't be saved to the specified location. verify that the original source files used in your movie are still available, that the saving location is still available, and that there is enough free disk space available.
    All these requirements are fulfilled but it still doesn't work. I also tried saving on a CD or sending via e-mail. Nothing works.
    What is wrong?
    Thanks,
    J
  2. papabear
    papabear
    May 26, 2005
    93
    11
    London
    try getting a format convertor. WMM will not accept AVI formatted video clips you need to chage that format!!!!
  3. Cam Korda
    Cam Korda
