Saved games!
Discussion in 'PC Gaming & Rigs' started by ytgti, Apr 6, 2003.
  1. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    I have a game saved on my old PC, which is packed up collecting dust. I now have installed that game on my new computer but don't want to start from the begining. Can i somehow email the saved points, or whole game from the old pc to the new one?
    Cheers.
  2. nathan_silly
    nathan_silly
    What game is it?
  3. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    Star Wars Jed Knight 2: Jedi Outcast.
  4. Garrett
    Garrett
    Apr 21, 2001
    39,878
    2
    167
    The best thief you’ll never see.
    +6,538
    Can’t you either copy it to a floppy, burn it to a cd or connect the two HD (better using two different cables for it) making the old drive the slave.
  5. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    Could do Garret, i'm not to up to scratch when it comes to things like this!
  6. nathan_silly
    nathan_silly
    Haven't got that game, so can't find the filename for the savegame/profile.
    However- open up Windows Explorer, go into the directory the game is in, and Press CTRL F. Type in *.* in the first option. It'll show all files in that dir.
    Resort by modified- hopefully your save game should be latest. See what directory this is in, (ie might be Save dir) so copy all files in that dir to a floppy/over the network- and copy to your new PC.
  7. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    Thanks. I'll give it a go... Now were is that old PC!
  8. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    Sorted guys, cheers. I burnt it to cd, tried email but it didn't seem to work. You've saved me alot of drinking.:laugh:
  9. Garrett
    Garrett
    Apr 21, 2001
    39,878
    2
    167
    +6,538
    I do not know if you got it running but just open the game file up and there should be a save game folder, open it up and if it has unlimited game saves just open the save from your cd, and drag it across and click on copy here.
    If there is not a save file play the game save and take a new look, it now may have created one.
  10. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    Yeah, i've done now! :smoke:
  11. Garrett
    Garrett
    Apr 21, 2001
    39,878
    2
    167
    +6,538
    The saves are in GameData open that up then open base then save or replace the save file. If you are playing all ready:blush:
  12. ytgti
    ytgti
    Jan 31, 2002
    533
    Lincolnshire
    I did it at 5:17, when i posted. :smashin:
