Its on the Hunted Mission, you must wait until Price gives the order and then kill the 3 enemies.Hi,
I want to go back and get this achievement, can some kind soul please tell me what level this is on?
Not sure about this but I thought the TV's are scattered through the levels and you have to find/ destroy them all.Got that one thanks, was fairly easy.
What level is the achievement for destroying all the TV's in please?
TIA
You're thinking of intelligence items.Not sure about this but I thought the TV's are scattered through the levels and you have to find/ destroy them all.
Yeah maybe. It's just not explained properly. There are TV's on other levels I remember shooting some in the 2nd or 3rd level. If the acheivement says to destroy all TV's and you get that by shooting them in one level but there are others in other levels.You're thinking of intelligence items.
The achievement description says "Destroy all the TVs showing Al-Asad's speech". I'm pretty certain that only the TV's on that one level are turned on and are showing the speech.Yeah maybe. It's just not explained properly. There are TV's on other levels I remember shooting some in the 2nd or 3rd level. If the acheivement says to destroy all TV's and you get that by shooting them in one level but there are others in other levels.
Thanks for the heads up though.
I stand corrected.....You may see other TVs broadcasting the speech in other levels, but you don't need to shoot them for this achievement....
That is what confused me. I had not looked it up on the tinternet and just read the achievment text. Started the game on the second run through and within 10 minutes of the game starting (not including the intro bit) I came upon a house in the marshes with some terrorists in and a TV showing the speech. I gave that TV a good shooting and have been looking for others. Well I know I don't have to do that any more. The TV's not required should be showing itchy and scratchy or something to make it obvious that they are not needed. IMO.I stand corrected.
if i remember correctly there are 2 before you reach the main building.Thanks for all the replies guys..
tried this 4 times last night, pretty confident I got them all and used the video guide above but did not get the achievement.
How many are in the outside buildings before you get to the main room?
TIA
Ok from what i remember there is 2 tv's in the first building you enter and from there you go down the main highway and there is a building on both sides with tv's in.Thanks for all the replies guys..
TIA
Hi mate,Any Luck CatManDo ??
Deftones82
