"Save for web" colour loss in PS
Discussion in 'Photography Forums' started by geofftelforduk, Mar 23, 2006.
  1. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    Guys,
    This has probably been asked before, but why does an image seem washed out when you view in the save for web preview screen in comparison to what it looks like in a normal photoshop window!?
    THanks for your help!
  2. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    It depends what settings you have got the save to web tool set to.
    There are a number of presets on the right hand side of the window - the tool defaults to a fairly aggressive 128 colour GIF I think if you don't change it.
    Steve
  3. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    Steve
    Yeah I know exactly what you mean! I would never have a photo saved as a GIF! Its always a JPEG! But even 100% quality doesnt make any difference to colours!
  4. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    Hmm, I wonder if the colour management profiles are disabled when you save for web. That's the only other thing I can think of which could explain the difference?
    Steve
  5. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    Mmm, I am not sure! Have you any idea how I would check to see if the colour management profiles are disabled or not?
  6. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    I'm having a tinker at the moment - but to be honest, I can't see the symptom you are describing anyway which makes it a bit tricky...
    What version of Photoshop are you using? I've got access to 7.0 and CS
    Steve
  7. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    I am using CS on an iMac
  8. Peakoverload
    Peakoverload
    Dec 1, 2003
    923
    43
    +198
    Go to the Save For the Web Screen and you'll see a little triangle shaped arrow in the top right corner directly above the preview screen. Click on that and select Use Document Colour Profile.
    You probably have it set to Uncompensated Colour which is the default IIRC
    HTH
  9. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    You beat me to it by eleven seconds!!!
  10. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    Excellent guys! I will try that when I get home from work tonight!! That would be fantastic if that is what the problem is!!!!!
    CHEERS :thumbsup:
