Save As JPEG - Photoshop CS2 question
Discussion in 'Photography Forums' started by lmccauley, Aug 26, 2006.
  1. lmccauley
    lmccauley
    Oct 24, 2000
    3,631
    Newcastle
    +397
    I imported a RAW photo into PS CS2, but when I try to save it as a JPEG, the only options that come up are for Photoshop, Cineon, Large Document Format, Photoshop PDF, Photoshop RAW, PNG and TIFF. Where's the option to save as JPEG?
    Cheers,
    Liam
  2. Liquid101
    Liquid101
    Jan 30, 2006
    8,072
    Aberystwyth
    +3,151
    Is it in RGB?, because if you converted to Lab it won't allow you to save as JPEG.
    Also, try saving as a TIFF, reopening and then saving as JPEG
    HTH
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,631
    Newcastle
    +397
    Aha, I found it - it was because I had it set at 16 bit. Thanks for the clue that led me to the right menu.
    Cheers,
    Liam
