sats drooping
Discussion in 'Home Cinema Speakers' started by WeirdFish, Oct 19, 2003.
  1. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    This may have been discussed before but I can't find anything.
    How do you stop the Kef eggs from drooping. I'm tempted to add some silicon sealant to the ball joint thing but I'm wondering if theres a better way.
  2. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Don't worry, it happens to all guys from time-to-time. If you worry about it it'll just make things worse. ;)
    MuFu.
  3. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Also worried if they're big enuf. Does size matter? :(
    :p
  4. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    It most definately does.........:D :eek:
  5. chris
    chris
    Nov 20, 2000
    1,226
    +28
    are these drooping because they are attached to the wall......????
    If so....can you not just hang them upside down.
    Sorry...i dont have experiance with theses speakers......i got B+W VM1's and they grip the ball joint (tighten with an allan key).....mine are pointing(faceing) towards the celling and have never moved.
  6. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Yeh they are attached to the wall and its a ball joint and its as tight as it gets (innuendo anyone?:p ). Unortunately you can't hang them upside down without modding the screw holes, altho that is a possibility.
