Satnav for BMW 5 series (E39)
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by FaxFan2002, Aug 17, 2005.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,432
    63
    Andover
    +160
    I have 5 series E39 ('02) with the standard radio / tape(!!) combo. I want, ideally, to replace the entire facia with the screen (fold out of static) with a minimum of satnav. Anyone got any ideas what I could use (links would be nice as well).
    Thanks.
  2. Gazpilot
    Gazpilot
    Aug 24, 2004
    82
    Depends on your budget, you can buy cheap motorised screens off ebay and add a GPS system or go the whole hog and get something like the Alpine IVA D310.
    I have an Alpine IVAD300r with an Alpine DVD GPS system, quite expensive but fantastic once you add rear headrest screens, PS2 and DVB-T.
  3. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,118
    Southampton
    +264
    If you check on some of the more estabilished BMW forums, you'll find that if you manage to get hold of the original Beemer sat nav unit, it will be quite a complex install to complete, even though it was designed for the car in the first place. There is an amazing amount of electrical wiring in the way of looms to contend with, & the associated modules, aerials etc, are hidden all around the deepest recesses of the car.
    Rgds
    Jerry
  4. DaveA
    DaveA
    Aug 26, 2004
    70
    Chester
    www.bmw5.co.uk - Search the E39 and Tech talk sections of the forum. Lots of knowledgable peeps.
