satnav for a usa holiday
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by bluedude1875, Jan 23, 2008.
  1. bluedude1875
    bluedude1875
    Jan 23, 2008
    25
    4
    south birmingham
    Any ideas which one to buy? I dont want to spend too much! Can i buy a cheap tom tom and download usa maps? How much would a downloaded map cost? Against a sat nav with it already on? Thanks folks...:thumbsup:
  2. Ginsoakedboy
    Ginsoakedboy
    Jan 22, 2008
    37
    11
    Get a Nokia N95 and download the maps free via wireless before you go?
    GSB
  3. jolly
    jolly
    Dec 5, 2003
    3,478
    83
    North Yorkshire
    +153
    I believe Garmin is an American brand, so should be well supported over there
    Steve
  4. bluedude1875
    bluedude1875
    Jan 23, 2008
    25
    4
    south birmingham
    ive got a nokia n95 with maps... problem is it costs a small fortune to use gprs over there, as you will be using a substitute server. ie t-mobile usa :(
  5. malc_gsi
    malc_gsi
    Oct 29, 2005
    68
    London
    +3
    Theyre really cheap to buy over there, I got a garmin from Walmart for around £120. Great if you're a regular visitor, mine just sits in the cupboard and is resurrected each time we go back.
    I've got built in nav int he car so it's not needed.
    The other option is to rent a unit but at £50 a week, its cheaper to buy outright if you visit often.
  6. TeamGers
    TeamGers
    May 21, 2007
    620
    28
    +28
  7. malc_gsi
    malc_gsi
    Oct 29, 2005
    68
    London
    +3
  8. Ginsoakedboy
    Ginsoakedboy
    Jan 22, 2008
    37
    11
    Unless I'm missing something, it is not GPRS that costs anything, it's downloading the maps. Therefore, from home, use the N95 wireless connection to download the maps of where you want to go for free. The Nokia will save the maps to its memory card, and simply overlay your GPRS location whilst you are there. That's what I plan to do when i go to Boston in a few weeks - I have already got the map ready and waiting on my phone.
  9. bluedude1875
    bluedude1875
    Jan 23, 2008
    25
    4
    south birmingham
    to use maps you need gprs ie mobile internet, which will cost a small fortune in the usa! i looked into that last year, thats why im going for sat nav this time mate.
  10. Ginsoakedboy
    Ginsoakedboy
    Jan 22, 2008
    37
    11
    Sorry, it's me mixing up my terms... I meant GPS not GPRS. The N95 uses GPS for location which is the same as a Tom Tom or similar and that does not cost anything - you can use the GPS without being connected to the internet, via GPRS, 3g or anything else.
    GSB
