Satellite Speaker Wall Mounts
Discussion in 'Home Cinema Speakers' started by geenuis, Apr 19, 2002.
  1. geenuis
    geenuis
    I've recently won an 'LG DA-3520' Home Cinema System which is nice :) (I wouldn't buy one however).
    The problem is i can't find speaker wall mounts to accomodate the small satellite speakers. The ones i did try required you to screw into the speakers and thus invalidate the warranty. :(
    Does anyone out there have any recommendations, the specs are as follows:
    Width : 90mm
    Height : 125mm
    Depth : 106mm
    Weight : 0.7kg
    At the moment they are hanging from screws and pointing straight so they dont sound too great, they have screw holes on the back but nowhere else. Any help is much appreciated.
