Satellite Signal - Strength v Quality
Discussion in 'Satellite TV, Sky TV & FreeSat' started by lonewaller, Jul 29, 2005.
  1. lonewaller
    lonewaller
    Is there any link between the strength & quality of the Sky signal?
    I have a signal strength of 85-90% but quality of only c20%. A friend has signal strength of around 50% yet his quality in c80%.
    This question is linked to another thread where I asked about any problems with adding an extension cable (max 3mtrs) between the receiver & the Sky box - I may need to move the tele.
    Brian
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The quality is a measure of the decoder errors, so with 0% errors, you get 100% quality. If you've only got 20% quality, you have a problem - that's a lot of errors ! Probably a mis-aligned dish.
  3. lonewaller
    lonewaller
    Is there an easy DIY way to check this, or should I pay for an engineer to visit?
    As I live in an area of bad reception (can't get to the main transmitter so have to use a secondary one on reduced power) I wouldn't say no to better quality.
    Brian
