Satellite finder meter
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dugit, Apr 30, 2005.
  1. dugit
    dugit
    Apr 29, 2005
    93
    I have seen the relative cheap satellite finder meters sf-95 and slx advertised, whbut do not no which is best to get, any advice onmeters please?
  2. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    Sky give their engineers a cheap Promax meter as back up should the digi meter fail. I used it a few times when the battery on my digi meter failed-it gave BETTER results than the digi meter!!! This was backed up be doing an install with a digi meter,aligning the dish to the best the digi meter reported,noting the readings then re-aligning the dish with the promax. Following alignment with the promax the digi meter was reconnected,it's readings were HIGHER! The software on the digi meters used to be bad,too slow to react,not sure what it's like now as i don't work there but the £20 Promax gets my vote!!
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I would advise getting one with an audio indicator, because you can't always see the meter in some instances (i.e. when it's connected to the other end of the co-ax 20 feet away).
  4. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    Yes agreed-the Promax i mention had audio-the higer pitched the noise the better the signal-makes things VERY easy ;)
