Satellite DVB-S/S2 + 1x Hybrid DVB-C/T
Discussion in 'Satellite TV, Sky TV & FreeSat' started by stevenjonas, Feb 24, 2014.
  1. stevenjonas
    stevenjonas
    Nov 20, 2011
    52
    I'm looking for a satellite receiver which can take 1 x DVB-S/S2 feed & 1 x Hybrid DVB-C/T feed. So far I have found the Vu+ Duo2, which is an amazing machine but very expensive & the GiGaBlue HD 800 UE+, which is considerably less, but without any instructions in English & only comes with a continental European 2 pin plug. Surely there is something else out there which doesn't cost as much as the Duo2, but still serves my purpose?
  2. Delvey
    Delvey
    Jul 20, 2008
    9,321
    Manchester
    +2,942
    Duo or Uno. But they also come with a European plug
  3. stevenjonas
    stevenjonas
    Nov 20, 2011
    52
    Thanks.
    According to the Vu+ web site, they do not come with a Hybrid DVB-C/T socket. Why do you say different?
    Is there any reason why I couldn't cut off the European plug & attach a British one instead?
  4. stevenjonas
    stevenjonas
    Nov 20, 2011
    52
    I understand that it is possible to fit a DVB-C/T connector (or 2) to the Vu+ Ultimo. What is the Ultimo like as a machine? Is this task easy (for a novice like me) & where would I buy the correct DVB-C/T from?
  5. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,285
    +899
    Amiko mini combo is available for £99. No idea if its any good though
  6. Delvey
    Delvey
    Jul 20, 2008
    9,321
    Manchester
    +2,942
    Because they can be added
  7. stevenjonas
    stevenjonas
    Nov 20, 2011
    52
    Thanks. I have found videos on YouTube showing adding a Hybrid DVB-C/T socket to the Duo to the removable patch at its back for that purpose. I cannot find any videos for the Uno & I cannot see any patches on the images of Onos. Nevertheless, you say one can on Unos?
  8. Delvey
    Delvey
    Jul 20, 2008
    9,321
    Manchester
    +2,942
    Seems the uno is discontinued. However take a look at the ultimo. These can have hybrid tuners
  9. stevenjonas
    stevenjonas
    Nov 20, 2011
    52
    Thanks again. I have been looking at the Ultimo. It certainly ticks my box so far as a hybrid DVB-CT socket is concerned. But it is a significantly older machine. Is it up to modern requirements?
  10. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Icecrypt 3700HD will suit your needs, 2 x dvb-s2 and 1 x dvb-T/C input, can be picked up for £150, and is pretty feature packed, nice and clear menus and can record to usb hard disk.. it's very good value for money.. The only thing that its lacking is its DVB-T not T2 and also does not decode DTS.., but then again no receiver I know of does, if so not at under £300
    The vue+ are way overprice for what you get.. on the other hand the 3700hd is way too cheap for what it can do. Be aware that asked for dvb-c/t, not T2/C2, so you will not get HD channels for cable and freeview
  11. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
  12. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    I meant icecrypt, for some reason I remember 3700hd but can never remember the manufacturer, I can remember humax, triax, technisat, but not icecrypt mainly cause not many people mention the name
  13. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    Very true!
  14. stevenjonas
    stevenjonas
    Nov 20, 2011
    52
    Many thanks. It looks a good machine. Can I add a hard drive to it?
    Also, why won't I get HD from a Freeview terrestrial feed?
  15. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,677
    London
    +481
    The Icecrypt 3700HD is simply a re-badged Amiko Alien SHD8900.
    These are basically all re-badged STi chipset boxes from the Fulan stable which serve the cheap and cheerful end of the spectrum.
  16. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Because it only has a DVB-T tuner and NOT a DVB-T2 tuner which is needed for Freeview HD.
  17. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Yes USB
  18. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,677
    London
    +481
    It runs Fulan's Spark based images or can dual boot specific/hacked derivatives of E2 images designed for Sti chipsets.
    Unfortunately images have been known to be unstable, juddering HD pictures and they can be slow/freeze etc etc. The tuners are also fixed and not pluggable and with no DVB-T2 you will ultimately be restricted to what you have.
    I would therefore suggest that you check out various user experiences of these boxes beforehand.
