mrvillicus
Hello all, we moved into a rental recently and I'm having an issue with the aerial. The property has a sky dish installed and the landlord has told me he previously had Sky.
We purchased a Freesat box and although it'll find 108 channels, once we click on a channel all we see is "no signal", during the setup process it also said "Freesat transponder not found".
This leads me to believe there is an issue with the satellite dish, what I don't understand is why it'll pick satellite channels up but can't find a signal, would anyone have an idea what the issue may be?
There's also an issue with the normal TV antenna, it simply doesn't work, we can't get a signal at all from it which leads me to think this must of been disconnected at some point. I've attached some images of the wiring that's coming into the house in case it helps.
many thanks
many thanks
