Gjones25
Hi, I have two CS100 cables that run along the skirting in my flat. I'm in the middle of redecorating, putting down new flooring, and I want to run the cable under it, embedding it in the 6mm fibreboard. Only problem is it's thicker than 6mm.
It was thinking of cutting the CS100 cables at the wall and joining WF65CU shogun cables to it using 90 degree connectors. My question is will this work? Joining two different types of cables? Or do I need to run the WF65CU directly from the dish?
Lastly is WF65CU the best cable under 6mm?
I would be using it for freesat or Sky+. The distance from join to box is about 11-12 meters.
Link to the cable I was looking at:
Webro WF65 CU Twin Coax Cable Black (priced per metre) | Maplin
Any help or advice would be greatly appreciated! Thanks
Gareth
Gareth
