Satelitte Recommendations - Free to Air?? Freeview??
Discussion in 'Freeview & YouView' started by WBC, Jan 9, 2003.
  1. WBC
    WBC
    I've had a complete gutfull of Sky Digital :mad: :mad: :mad:
    Will be cancelling as soon as I can replace with something else. I've been down the Cable digital route, they are worse!!!
    Has anyone got any links that will push me in the right direction of what I need or should be going for.
    Will buying a satelitte dish and receiver give me many more english speaking channels than normal FreeView????
    Can you get the likes of E4 going down this route????
    Thanks for your help!
    Stace :D
  2. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Royal County Of Berks...
    Not sure about E4, but if you've had sky digital for about a year, I think you'll get the free to air channels with the Sky card.
    Or you could call the Beeb for the fta sky digital card.
    Or buy a freeview box. Cheaper than buying a dish and stb - but less intetresting if you plan to make it a hobby - motorised dish, dual lnb etc.
  3. WBC
    WBC
    Are you suggesting that if I cancel my subscription with Sky, I keep the dish and receiver???
    How much is the BBC FTA Card???
    Stace :D
  4. Fernsehman
    Fernsehman
    I suspect you are really discussing "Free To View" for which you need a Sky Digital box and a "FTV" card or a Sky card. "Free To Air" means exactly that. No card required. E4 is not FTV.
    And may I politely point towards the top of this screen where it says "Digital TV, Satellite and Cable".
    Yes, that's how you should spell "satellite".
    :rolleyes:
    I mention this because a Google search for "satelitte" pulls up a lot less information than a search for the correct word, so you may find it useful to remember it.
    You keep the Sky dish and receiver if your cancellation is accepted by BskyB. It all belongs to you and you may keep it or sell it. I suspect that BskyB would prefer you to sell it because the buyer might want to subscribe.
    A Sky Digibox and FTV card will get you a LOT more English speaking channels than Freeview will. However, the actual programme content of the majority may not be as interesting. Depends how keen you are on Religion, Travel, news, shopping ...
  5. WBC
    WBC
    Thanks for pointing out my spelling error. I apologise but I am deaf in one eye. ;)
    What I was actually getting at is, do I buy a third party type of SATELLITE dish and receiver (you know the sort that mostly transmits the highest quality porn!!!) or shall I keep my sky box with FTA or just go for freeview??
    If, as I understand it, I keep my Sky bits then surely it must be more beneficial to get a BBC FTA card :confused:
    What sort of money would I get for the sky dish and receiver??? Would it cover an upgrade to the above???
    As you can probably tell, I don't have a scooby as to what I'm talking about so all the advice and recommendations are much appreciated.
    I basically want as many half decent channels as possible with as little outlay as possible (BBC Choice, Discovery Home & Leisure etc).
    Where can I get a list of Sky free to view ????
    Thanks Again
    Stace
    :D
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Might i suggest satalogue never used them but heard good reports, there are loads of sites. do a Google search for hotbird or satellite TV.
  7. WBC
    WBC
    I'll take a look. Any other recommendations would be appreciated.
    Stace :D
  8. DaveP
    DaveP
    I suggest you keep your existing sky equipment. Your existing card will become a FTV card once sky cancel your account. There will be no point requesting a BBC card.
    This is a zero cost option and will give you loads of channels all with the high quality that you are used to.
    DaveP
  9. WBC
    WBC
    Where could I get a list of Sky FTA channels?? Will it include the usual BBC etc
    Stace :D
  10. kevenh
    kevenh
    Jul 3, 2002
    342
    19
  11. WBC
    WBC
    Thanks for your response.
    Stace :D
