SATA Raid0 Question
Discussion in 'Desktop & Laptop Computers Forum' started by RobsterD, May 19, 2004.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    I'm running two Maxtors at the mo in a Raid 0 config but will be shortly putting them into a new PC ,will I need to re-format when I install in the new PC or will the new bios see the Raid0 config and allow me to use the drives without having to save 50 ripped movies !!!
    Any thoughts appreciated.
    Rob
  2. Kramer
    Kramer
    I'd suggest backing up your movies/data before the move. It's very unlikely the raid array will function correctly if changing mainboards. You may be lucky (same Raid controller etc.) but chances are you'll be formatting/reinstalling.
    Best of luck.
