sata drive not recognised by xp
Discussion in 'Desktop & Laptop Computers Forum' started by flyingmonk, Aug 17, 2004.
  1. flyingmonk
    flyingmonk
    hi, my wd 200gb sata 150 hdd is recognised in the raid utility b4 windows boots, but not in xp??
    i have an abit nf7 mb which accepts sata 100 +
    ne1 know if theres any jumpers to change, or drivers to be installed and where to get em.. etc???
    much obliged for any help
  2. Loftus
    Loftus
    Windows XP needs drivers for SATA controllers (i.e. they aren't included in the base install of windows). Check the driver CD that came with your motherboard.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,490
    South Derbyshire
    +199
    If its an NF7s you shouldve got a floppy with containg the drivers.
  4. flyingmonk
    flyingmonk
    i have the flopy, but i dont know where it is...? as i have moved out of uni n stuff still in boxes, also i got it appearing now by formatting it into ntfs through the disk management function.. i can put things on it now but videos are breaking up like i need new codecs but they work fine on my ide hard disk... do i still need to install drivers for sata as i have no floopy drive or floppy at present... n i want to do some video editing! (mp3's n programs seem to work fine, just not videos!)
    cheers
    oh by the way thanks for ur help :thumbsup:
  5. mjn
    mjn
    May 24, 2001
    22,429
    Herts, England
    +10,460
    you need to download the SATA drivers from the Abit website if you have lost them.
  6. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Yeah just get em from the website, should tell you exactly what you need !
  7. flyingmonk
    flyingmonk
    cheers I installed new drivers n it worked, then i couldnt delete a folder, so i thought, ahhh ill just formatt it now it works, start off with a clean sheet. And it didnt formatt, so im tryin it again... cheers 4 ya help hopefully it will formatt this time n i can make some dvds of my mates band finally!
    nope it keeps sayin it cannot be formatted n i cant get in the drive...
    anymore help?
  8. flyingmonk
    flyingmonk
    i dont suppose theres a way of formatting through the raid utillity before windows boots?????????? maybe that would work..
  9. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    depends what controller it is. my a7n8x deluxe gives you options to go into the raid controller options when it's booting just after the bios screen. i found i had to format it through there first before doing it in windows !
  10. flyingmonk
    flyingmonk
    hmmmm.... got it workin again, as in i have formatted the drive. but once again my videos have stopped working? i tried to reistall the drivers again n it didnt fix it.. im so very annoyed! also some of my folders wont let me in! a folder 1ith 9gbs of data in and a folder with 24gbs howerver a folder with 4.36 gbs will let me in altho previous to my last formatt it wouldnt.
    last time i ask for help otherwise im gonna send it back, i have emailed WesternDigital about the problem
    also i ran hitachi fitness test and it said everything was fine
    cheers 4 ya help again
  11. mjn
    mjn
    May 24, 2001
    22,429
    Herts, England
    +10,460
    what file system are using?
  12. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    if the drive formats without error there's nothing wrong with the drive ! western digital have a utility for low level formatting, try that. also did you format the drive using your sata/raid controller ?
    i'd say you have something wrong in windows with the drivers
  13. flyingmonk
    flyingmonk
    i emailed Western digital.. n after a lot of installing resterarting d/ling it finally worked, heres what you need if youre having the same type of problems...
    There are 2 reasons for these issues:
    1)
    Title: Data corruption problems in EIDE drives larger than 137GB (128GB binary) in Windows XP.
    URL: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=903&p_created=1045153821
    2)
    You also need the following Windows update to have the drive supported in XP:
    http://support.microsoft.com/default.aspx?scid=kb;en-us;303013
    PLEASE GET SERVICE PACK 1 (XP) HERE:
    http://www.microsoft.com/windowsxp/pro/downloads/servicepacks/sp1/default.asp
    thanks to WD for their help and everyone on who posted... most appreciated
