Sat & tv distribution help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Chris77, Jun 10, 2015.
  1. Chris77
    Chris77
    May 19, 2010
    2
    Looking to fit a new distribution system as I'm renovating, looking at using diplexer skts by each tv in bedrooms, kitchen and lounge. Have humax free sat boxes and a tv with freesat, the others are freeview.
    What I'm looking at is the Triax TMP 5x12 running wf100 twin to each room plate (2xsat 1xtv 1xuhf)
    What size dish do I go for south coast uk?
    The 4 sat feeds that goto the TMP will I be ok with 15-20m wf100?
    On the terestial side what triax combiner do I need here ? Tv / FM / Dab
    TV antenna is fine need to add new fm/dab is there a combine antenna?
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,626
    Redditch
    +4,208
    80cm round dish and Quattro lnb. Normally best to use one size up from normal to cover losses in a multiswitch. You may be OK with 60cm. You will need a UHF/FM/DAB multiplexer as the multiswitch only has a single terrestrial input.
    Datasheet available from here
    Triax - TMP 5X12 Stand alone
