Sat Nav's under £150
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Westender, Apr 29, 2007.
  1. Westender
    Westender
    Jun 14, 2004
    60
    London, UK
    +10
    Looking to get a cheapish sat nav for under £150. Will only require for ocassional use (don't require for work) and uk based holidays. I've been looking at the AA Navigator Vive, the Navman F20 and Garmin C320. The AA device got 4 stars in a recent autoexpress review but can't find many user comments on the web. Any suggestions?
  2. stockyvillage
    stockyvillage
    Apr 6, 2006
    1,217
    liverpool
    +91
    try chicargo 6000 £149.99 at halfords.Free updates for software and speed cameras for life of unit.4.3" widescreen mp3 player and navteq navigation.Sirf 3, got one myself cant fault it at the price
  3. solidamber
    solidamber
    Dec 6, 2006
    1,225
    Cambridge
    +138
  4. kraiklyn
    kraiklyn
    Dec 18, 2002
    1,202
    +60
    Maplins are doing one for £99. Looks ok too.....
    Large 3.5 inch touchscreen and included stylus showing 2D and 3D view in day/night mode
    Full UK mapping with 7-digit post code on SD using Tele Atlas maps
    Remote control, car charger and home charger included
    MP3 player stores your favourite songs via SD card
    Sirf star III antenna for optimum GPS signal
    Built-in battery lasts up to 3 hours
    64MB flash memory
    http://www.maplin.co.uk/Module.aspx?ModuleNo=115145&TabID=1&source=1&doy=30m4
    You can probably find vouchers on the web to bring it down to £92.99.
  5. SimonCee
    SimonCee
    Mar 31, 2007
    Birmingham
    You can get a Tomtom One from Amazon and The Link at the moment for £154.88.
    I know its over your £150, but only just...
  6. hanxslf
    hanxslf
    Oct 12, 2003
    153
    north yorkshire
    +4
  7. 16641664
    16641664
    Promo codes (FT4AGZ) are available for the Tracker Journey product (re branded Evesham Nav Cam 7000/7500 buy the looks of it). I tried the code in the tracker journey website and got £150 discount!!! That is a £250 sat nav for £99!! Looks good with speed cameras, 7 digit post code, touch screed etc.
  8. gaz100uk
    gaz100uk
    Jan 16, 2006
    105
    you can now get the TT one from Halfords for £144.99 inc delv. Just buy it on-line and add the promo code HAL5OFF after all your delivery details.
  9. stockyvillage
    stockyvillage
    Apr 6, 2006
    1,217
    liverpool
    +91
    Had an Evesham Nav Cam 7000 it was absolutely c***
  10. gaz100uk
    gaz100uk
    Jan 16, 2006
    105
    Well, just bought myself a TTone for £134.99........from currys. Its up for £149.99 and till 4pm if you enter friday as a promo code you get it down to £134.99...dont thing i can beat that...
