Dear all ,
I would like advice from you all regards a satnav + dvd solution with a 5.1 surround sound suitable for a car .. can you help please.
The car is a Jaguar xj8, 1998 model.
I have searched high and low on the net for possible solutions and as well as visited my local AV car shops .. the shops here dont have much experience but said they can do it.
I seen on the net pioneer unit that does sat nav and dvd single din but sound is in stereo only .. there are two add ons one is a pioneer DEQ 6600 ( i think) which is a DSP 5.1 with 50wx5 output ( sounds good) other option is a alpine similar device (not amped -- i may be wrong) has any one had use of these .. i am considering using the factory speakers in the car .. will need to add a centre speaker and was also contemplating chanding the rear speakers ( door) geting rid off the standrad mid range woffer with a six inch sub in the door.
please any one done this .. can any one share there thoughts please .. thanx .... regards .. KK
