Sat cable for sky hd
Discussion in 'Sky Digital TV Forum' started by sirata, May 15, 2005.
  1. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    I am bulding an ht at the moment,i am at the putting in cable stage. I want sky hd when it comes out, does hd run ok down ordinary sat cable that runs from my LNB at present,or do i need something better
    Dave
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    No worries, the actual content of the signal is not significant as long as the cable quality and connections are of good quality to begin with.
  3. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    cheers starburst
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I think you are already going to do so but make sure you have at least two sat cables, the first SKY HD box is going to be a SKY+ variant which requires two feeds to be of any real use.
    Of course if you are building from scratch wiring up all the LNB outputs and concealing them is the way to go:)
  5. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    I am going to keep the existing sky box in the lounge for regular sky, are you saying i would need 2 cables just for the new sky hd box ?
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,256
    Manchester
    +753
    3 - one for the original $ky box and 2 for the $ky+ box (which has 2 tuners).
    Since they'll be installing a quad LNB you might want to put in all 4 possible cables , i.e. fit a cable run to each output from the LNB.
    Chris Muriel, Manchester.
  7. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    Thanks Chris
