Question Sapphire screens?
Discussion in 'Projectors, Screens & Video Processors' started by panman40, Jun 18, 2015.
  1. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
  2. Coz22998
    Coz22998
    Jan 11, 2005
    7,648
    263
    177
    Stockport
    +25,267
    I'm using one (see my sig - 92" fixed frame) with my JVC X3 and not had any problems at all. No blooming/hotspots, ripples or anything at all (love the velvet frame but the Sapphire badge slap bang in the middle of it is a little large!!! :)). It is in a complete bat cave though but I'm really happy with it.
  3. Deuce
    Deuce
    Apr 29, 2015
    207
    46
    UK
    +168
    Hi, thats the screen I have & from the same place.
    There is VERY slight curl in the black boarder other than that it's fine, been using it 3 or 4 times
    a week in the 8 months I've had it.
    Hope that helps read about all the bad luck you have had.
  4. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    I've had an electric sapphire screen for a long time now (probably 8 years+) and its still looking good with only VERY mild rippling that's well within acceptable levels.
  5. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    Hi, thanks for that, having very slight edge curl would be perfectly acceptable to me, my previous optoma screens had very bad curl which affected both sides of the viewing area, this Grandview I have is showing signs of curl already, I'm not sure if it's due to the strange crimping though.
    I'm going to go for the sapphire now, I'm a bit concerned as its over £100 cheaper than the Grandview but hopefully it will work out ok!.
  6. razy60
    razy60
    Jan 13, 2008
    1,285
    83
    Eastbourne
    +322
    Got that screen to replace the non slow retraction one, much better product, minor curl as has already been stated. They have a good returns policy if the screen is faulty
  7. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
    These do look incredible value for money, you can get the manual 92" for about £135 delivered.
    I think this is definitely on my list.
  8. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    I can recommend Ricky from Kalibrate, that's where I ordered mine today.
    Coming next week.
  9. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    Sounds good, I did want the slow retraction feature as I once had a little mishap after a bottle of red wine... The handle just seemed to slip from my fingers!, boy did it go with a bang!.
    I can accept a little edge curl at this price, just as long as it doesn't affect the viewing area.
  10. razy60
    razy60
    Jan 13, 2008
    1,285
    83
    Eastbourne
    +322
    Been there too, nearly lost my TV as it caught it on the way up:facepalm:
  11. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
    I didn't realise he did them, thanks for the heads up.
  12. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    Just incredible this. My sapphire was delivered today at 5pm, box was pretty messed up, I could not see any damage apart from the bottom bar on the right side hanging down a cm or so. I hung it and pulled it out... The handle had been twisted around in the box and caused a stretch in the bottom border, a tear on left side of the backing, I found it very stiff to get the screen down but managed it, on retraction it goes up maybe 1/3rd then jams solid.
    I just don't know what to do anymore apart from find out where the distributer is and travel hundreds of miles to hand pick one and take it home myself :-(
  13. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Speak to Sapphire they are only in Wales
  14. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
    Unbelievable I can't believe the luck you have had with these screens. Hopefully they will sort you out. Apart from the issues how did the material etc compare to the Grandview.
    @Aclass Technology, I know you sell these screens do you have many problems with them?
  15. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    That might just as well be a million miles away. Only 2 couriers I'm told accept screens as big as 106", TNT being the other. My van is only a short wheelbase so it won't fit in. Mind you when I saw the screen in the back of a 'tuffnels' delivery van it wouldn't make a lot of difference..
    I'm just so fed up of it all.
  16. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Not one, and any issues just call Sapphire and they sort.
    Not supposed to be a sales plug just that we have used lots over time and Sapphire have been excellent
  17. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    I meant call them and see what they can do for you
  18. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    Me neither pal, I thought the material was good, possibly between the grandview and Optoma, only very slight crimping apart from a heavy crease in the left border but basically no edge curl at all. If I could only get a good one of these sapphires it would be perfect.
  19. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    All made in the same factory so material is identical
  20. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    After having several Optoma screens before this I would have to disagree the material is all the same, unless of course it's yet again quality control.
  21. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    I can't say for definite but did visit the factory a few years back
  22. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    One flaw in the sapphire packaging which imo has caused the bottom border stretching, the handle protrudes further than the polystyrene packing ( I placed it close so it can be seen). The handle gets twisted which twists the bottom bar and in turn stretched the material.
    The second pic is the impressions in the cardboard box opposite the handle. This is made worse as the screen is boxed with the handle facing down.
    I spoke to the Welsh distributor this morning myself but they could not help me, it had to be my retailer that contacted them which he's done despite me knowing he's very busy this week.
    [​IMG]
    [​IMG]
  23. PH001
    PH001
    Nov 21, 2006
    419
    Harrogate, N. Yorks.
    +17
    Very poor packaging that - no excuse. They should get their act together.
  24. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    Well the replacement arrived yesterday.... Gobsmacked at the state of the box and was going to refuse delivery but the wife said sign for it damaged as she's had enough of waiting in for deliveries,
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The box was wedged between a spare wheel and another large box, anyway after checking I was gobsmacked it wasn't trash, I think the bottom bar has been twisted as it hangs down a little in the middle but does not affect the material.
    There's a small crusty type lump on the rear left side edge where looks as if the backing paint was blobbed then broke off, this doesn't impact on the front side.
    Screen retraction is much smoother but only just manages to get it rolled up fully under its own steam, I think this screen would have been perfect if it wasn't for the harsh delivery journey.
    For my wife's sake and my own insanity I've decided to keep this one now and hope it keeps retracting ok in the future.
    Happy days....??? Well it's a start lol!.
  25. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
    Is that the handle that pulls the screen down, it looks pretty big.
    If you still have it what does it measure from bottom of the handle to start of the white screen.
  26. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    The handle is pretty small really, measures 4" from bottom of handle to white screen, bottom border is 47mm.
    [​IMG]
    [​IMG]
  27. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
    So is this one a keeper then?
  28. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    According to my wife yes!, I tend to agree with her to, it has a 3yr warranty, watching Glasto on it tonight and it's an excellent image, seems to have no edge curl at all as yet. I would say for £200 for a 106" diag projection surface that can be retracted out of sight it's excellent.
  29. Russ 66
    Russ 66
    Jan 5, 2004
    2,002
    116
    Norfolk
    +1,468
    It looks like the 92" is definitely on my list then. The electric ones look good value too.
    Ideally I would get the Draper React but they are very pricy.
  30. panman40
    panman40
    Oct 19, 2008
    17,175
    +5,761
    Well.I've had Optoma, Grandveiw and now Sapphire, I like the compact casing on the sapphire and despite it being £100 less than the Grandveiw I prefer it and highly recommend it. Just make sure you get a good one and then get passed the rough ride delivery and you will be sorted.
    The electric versions I think would be great.
