MovieBoy75
- Joined
- Aug 10, 2004
- Messages
- 7,740
- Reaction score
- 1,230
- Points
- 1,526
i got my Sapphire screen from CVS - very helpful and excellent prices aswell.
Guido, how noisy is your motor when lowering / raising the screen? I have one of these and it sounds quite loud, sort of a humming sound and a (excuse the description) clanky bearing sound (will have to do an .avi of it in action). Bit concerned about mine as you said your one was very quiet.
Hi Guido
I bought a Sapphire SEWS180R very similar your the one in your pics just over 2 yrs ago. Recently the very slight clunking sound which mine also made turned into a very loud grinding sound and the screen won't retract any more. (screen goes down but not up)
Any advice on where I might be able to get it serviced/repaired???
George
Guido,
Bit concerned as to why your pictures are appearing on the CVSMedia website, see the following link:
http://www.cvsmedia.co.uk/shop/index.php?cPath=57_219_258_262
Either you work for them, and are not declaring it, they have nicked your photo, or you have given permission for them to use it.
For the integrity of your previous comments, I think we should be made aware of which one it is.
Thanks, James
