Sapphire Radeon 9000 Atlantis to Sony 11HT which connection?
Discussion in 'Desktop & Laptop Computers Forum' started by sea surfer, Mar 26, 2003.
  1. sea surfer
    sea surfer
    Jan 6, 2003
    4,766
    Glasgow
    +917
    Hi, just finished building my HTPC, I have installed the radeon 9000 card want to hook it up to a Sony 11HT projector, looking to acheive the best possible picture for surfing the web and also viewing dvd,s.
    Which cable should i use, and where can i buy it?, the card has a dvi output but the proj does not have a dvi input.
    Any help would be appreciated.
    Thanks.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    After DVI, I'd choose std. RGB you should be able to find a long monitor cable online.
    edit: removed the S-Vid stuff, checked the Projector specs, it can accept 15pin d-sub RGB.
  3. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    The 11HT doesn't have a 15pin D connection.
    You need to get a 'VGA breakout' 15pin D to 5 phono (RGBHV) lead an connect to either input A or B on the projector.
    Don't forget to configure the input to 'computer' in the projector menu!
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    MarkHudds,
    Just realised :blush:
    someone has replied with this advice together with a cable reccomendation to a duplicate post of this.
