saphire,powercolur,connect3d?
Discussion in 'Desktop & Laptop Computers Forum' started by andhoey, Nov 10, 2004.
  1. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    i was going to purchase a radeon 9600 pro 128mb all in wonder card (with remote). but is there much of a difference between the various manufacturers in my title ?
    im just starting to get things organised for a hcpc..thanks andy
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    There'll not be much difference hardware-wise between them, they're all using the same chipset so the only difference will be whatever software is bundled .. unless this is a card that comes with a fan in which case a few makes don't have one.
    Personally I've always used Sapphire but largely because that's the brand I find easy to get from where I buy my bits and pieces.
