SanyoPLV30 v PT-AE100
Discussion in 'Projectors, Screens & Video Processors' started by Me, Mar 17, 2002.
  1. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    I currently use a Sanyo plv-30 projector which I love and can not fault, especially for what it cost. I need to get a second projector for a new media room. My first choice would be another Sanyo however this Panasonic PTAE100 sound interesting. Is it a better projector than the Sanyo? They are priced very closely. I could save a few pounds on the Panny , but if the Sanyo is far better, then it is extra money well spent. Any thoughts.
    Mark.
  2. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    Emmmmmmmmm, I have the AE100, my Brother has the PLV-30.
    We have never done a side by side comparison, but I would choose the AE100 as it has a 16:9 panel, and it is quieter.
    Out of the box, the AE100 blows the PLV-30 to bit's, but once calibrated, the PLV look's pretty good, The PLV has a contrast of 400, the AE100 is 500, but we cannot see a differance.
    I would have to say screen door is about the same.
    I think the PLV may have slightly better video proccessing, but the AE isn't bad.
    One thing that puts me of the PLV (in componant) is the vertical lines I can see on sky scenes, it really did put me of, and gets worse with s-video and composite.
    PLV-30 is about £1800 (lamps around £300 2000hr lamp life)
    The Ae100 is about £1400 (lamps around £150 5000 hr lamp life)
    I know which one I would go for.
    If your unsure wait a couple of month's it should be easy to get a demo of the AE then, after the mad rush for everyone to get one as died down.
  3. Geoffc10
    Geoffc10
    Maybe you should wait for the HCC write up when the next issue goes on sale on the 21st!. If it gets Best Buy, then i think you can get the Panny, but they must have cut corners on the Panny somewhere
  4. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    Update
    We did a quick side by side comparison today with the Sanyo and the Panny in s-video, software was The Gladiator region 2.
    The contrast was about even, colour's were close, maybe the Panny was a little better.
    We found the video proccessing on the Sanyo was very good in s-video, but we could see vertical lines.
    The video proccessing on the Panny didn't seem as good, there was a slight ringing effect to object's, but it wasn't off putting.
    If you are happy with the Sanyo, and you dont mind it being a 4:3 projector, get yourself another one, but if you want 16:9 go for the Panny.
    I believe What video gave it 4 1/2 out of 5 star's, in the latest issue, this mag is made by the same company as Home Cinema Choice.
  5. Geoffc10
    Geoffc10
    The Sanyo has a 16:9 mode and displays widescreen. I have seen a demo. Its on par with one of the Sim Pj's
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I have the sanyo...... i wouldnt go as far as saying that it is as good as a sim, cause i dont think its even close, but its a very nice projector. There is no way on earth anyone could persuade me to change it to the panny!
    BUT!!! If i was buying a pj from fresh, i would be giving the panny alot of thought, mostly due to the cost.
    ad
