Sanyo Z3 - de-interlace the 480i signal into a 480p
Discussion in 'Projectors, Screens & Video Processors' started by Frankeh, Nov 7, 2005.
  1. Frankeh
    Frankeh
    Someone told me the following
    Does the Sanyo Z3 have this too? So does this mean there being no big difference between 480i and 480p?
  2. gingerone
    gingerone
    Dec 10, 2002
    2,592
    +406
    It depends entirely on how good the internal scaler is on the given display if it is better than the dvd players internal scaler then it will look better( if it is a progressive display).
    The Z3 will scale any non progressive image to 720p as this is it's native res.
    Unfortunately the internal scaler in the Z3 is not the best and I have found that I get a much better image when using the scaler in my dvd player and have the image scaled to 720p.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    If fed 576p I'm presuming it will scale a progressive signal too?
    ...PJ
  4. Frankeh
    Frankeh
    you are comparing it to a dvd player, actually I mostly play games on my PJ.. so you said the dvd player has an internal scaler, does a PS2 have one too?
  5. gingerone
    gingerone
    Dec 10, 2002
    2,592
    +406
    My understanding is that it will scale any image that needs scaling to 720p as that's it's native res, but with progressive signals there's no de-interlacing to be done.
    Some ps2 games have the facility for progressive scan but as far as I am aware the ps2 will just put out an interlaced signal otherwise.
  6. Frankeh
    Frankeh
    so when a game doesn't have a progressive scan option it will be shown as a interlaced signal?
  7. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,083
    Thats what the pj will be receiving so yes. If its anything like the Z2 and you have the input on auto then it might not specifically show in the menu as receiving an interlaced signal.
  8. Frankeh
    Frankeh
    so it all depends on the internal scaler.. can you buy an extra scaler, putting it between your pj and PS2/DVD ?
    is it worth it, good quality?
  9. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,083
    Yes, i think that the mains ones are Lumagen, Crystalio and DVDO Iscan.
    One of the problems of using it with your PS2 though may be a slight time delay.
    Alternatively for DVD you could use a HCPC with ffdshow.
  10. Anim
    Anim
    Feb 2, 2002
    1,686
    Bollington, Macclesfield
    +62
    You can also pass any console into a PC using the sweetspot input card if I read the review correctly.
  11. Frankeh
    Frankeh
    http://www.pluggedin.tv/sweetspot/index.html
    the question is, will it give any delay for consoles? + it costst 200£? whow for a card that's just too much as a student.
  12. Anim
    Anim
    Feb 2, 2002
    1,686
    +62
    its £149 INC vat not £200, but it will also allow you to feed Sky/NTL through it for a greatly improved pic (Dscaler and filters permitting). But i've never used it so can't comment on experience.
    Edit: it will pass through the signal so you shouldnt get any delay. If you start adding filters like noise reduction, resizing etc then it could cause a delay if your PC isnt fast enough to post-process.
