Sanyo Z3 and HDMI
Discussion in 'Projectors, Screens & Video Processors' started by gingerone, May 12, 2005.
  1. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    Hi all, I've heard people talking about issues that the Z3 has via HDMI and a pc, are these problems the same with HDMI via a dvd player?
    I'm thinking of purchasing a new dvd player and I don't fancy the projector crashing on me.
  2. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    I have no problems with a Panasonic s97 via hdmi to z3.
  3. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    Excellent that's what I wanted to hear.
    How much of an improvement is hdmi over component?
  4. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    there were initial problems with HDMI but they have been ironed out since early january. have a search and find out. i use a htpc dvi-hdmi lead and have a great picture. even better when i can find some hidef 1280x720p avi's off t'internet.
  5. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    Well I appear to have an issue via HDMI.
    watched a film last night and after about forty minutes, pj locked up and screen broke up in into large pixels.
    Had to pull power and let it cool down and turn it back on again.
    Bummer!
  6. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    I am thinking if I should buy the Z3 and because I will connect it with a PC I need to know if there will be any such problems.
    Is there any way I can tell if the projector is an OK one or not? (e.g. manufacture date, firmware version etc)
    If I do have such problem would it justify a refund or replacement?
  7. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    There's a 3 year warranty with the Z3 and they are pretty good by all a/c's so I would'nt worry.
  8. Geesus
    Geesus
    Dec 23, 2003
    1,714
    +432
    No problems here with HDMI between a Z3 and a Pio 868 - picture quality is absolutely stunning...but then again it is via component too :D
  9. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    gingerone, it sounds like you have the version 1 firmware, it needs upgrading to 1.01, which resolves this problem.
  10. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Ivojo, is there any way I can check what firmware the Z3 has?
    Also, can I do the firmware update myself if I need to?
  11. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    I don't think you can update it yourself, ken told me earlier that anything sold after january should have the new firmware.
  12. Meddy
    Meddy
    Apr 24, 2005
    147
    +8
    To check the firmware on the Z3 do the following:
    On top of the projector there are numerous buttons. Locate the "Select" and "Input" buttons and hold them down together for approx 5 seconds. A little box should appear on your screen in the top left corner indicating the f/w version. :lesson:
    Meddy
  13. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Hi Ken,
    I Had this problem occur last week and upon checking the firmware it is 1.01 :( Have you ever heard of this happening with this firmware version?
    Adrenochrome.
  14. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    No, we've not had a single reported problem with 1.01 software. Are you using a new dvd player, or have you changed any part of your system which may narrow down the problem?
  15. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    I'm starting to think the problem is with my dvd player as I watched my pj for ages last night with no issues at all.
    The night I had the problem I had been changing the settings on my player.
    Time will tell I guess.
  16. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Hi Ken,
    I Am using a Panasonic S97 to feed the Z3 and the lock up happened after a lot of fast searching through a movie.
    Adrenochrome.
  17. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    Well my projector is now locking up every time I use it, it happens after about an hour.
    I had a period where it did'nt happen much but now I get two thirds thru a film and it locks up.
    Looks like I'll have to give Ivojo a ring tonight.
