Sanyo Z2 High Fan Noise
Discussion in 'Projectors, Screens & Video Processors' started by kunter, Jan 3, 2005.
  1. kunter
    kunter
    Hi.
    I recently purchased a Z2 and I am quite happy with the performance. However there is a small problem I could not resolve.
    No matter what the lamp mode is, after about 15 minutes of projection, the fan starts at a very high speed. This is much higher than the full lamp mode. If at that point, I play with the lamp setting, the noise is back at the respective level.
    The projector sits on a shelf, nothing on the sides and top, and almost 20 cm from the back wall.
    Any comments will be appreciated.
    KK
  2. mr ooops
    mr ooops
    Mar 4, 2003
    3,592
    103
    Hardwicke and Wotton
    +353
    Had exactly the same problem, all be it mine was after 60 minutes use, making my front room cooler solved this problem, also 20cm may be to close and will hamper ventilation and will make the unit run hot, im sure i read in the manual it needs 50cm at the rear.
    hope this help
    jason
