Sanyo Z2: discoloured patch
Discussion in 'Projectors, Screens & Video Processors' started by Bert Coules, Aug 23, 2004.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    2,995
    +119
    My Sanyo Z2, bought secondhand six months ago, has developed a discoloured patch in the upper left-hand corner of the screen. Though it's barely noticeable on most programme material, light backgrounds show it up. I have a suspicion that this is due to the unit overheating: I've had to position it with less than the recommended clearance at the top and the rear, though the sideways clearance (where the ventilation output is) is very generous.
    I had something similar with my previous projector, a well-used Panasonic AE100. The cure was the replacement of the entire optic block. Has the Z2 been around long enough yet for it to be known if this is the same problem? Is it something which affects all LCD projectors?
    On the AE100 it was a simple matter to call up a service menu and project a series of single-colour blank screens. Is there a similar facility on the Z2?
    Many thanks.
    Bert
    http://www.bertcoules.co.uk
  2. Kramer
    Kramer
    Hi Bert.
    Are you sure it's not just a dust blob..............Z2s are relatively prone......
    :smoke:
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    2,995
    +119
    Kramer, thanks for the thought. Dust blobs are almost always circular and well-defined (if you focus on them) aren't they? This is a right-angled triangular area which peters out at the hypotoneuse edge.
    But just in case, I'll try focusing on the patch and see if I can sharpen it up. And I suppose it might not hurt to open up the case and squirt some air around...
    Bert
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Bert,
    It could be one of the polarising filters as these often become discoloured when subjected to heat or when they get old. I have seen this often on Sony VW projectors.
    It's often the blue polarising filter to go first.
    Jeff
  5. Bert Coules
    Bert Coules
    Mar 17, 2002
    2,995
    +119
    Jeff,
    Thanks for that. If it is one of the polarising filters, presumably it's not too big or expensive a repair. Do you know if I have to go through a dealer, or can I contact Sanyo UK direct?
    Bert
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Bert, I presume your Z2 is still under warranty.
    If you have the original receipt I would get in touch with dealer who supplied the unit or Sanyo themselves.
    Jeff
  7. Bert Coules
    Bert Coules
    Mar 17, 2002
    2,995
    +119
    Jeff,
    Annoyingly, the original receipt seems to have temporarily gone into hiding; I can't be sure if the Z2 is still under guarantee or not. Is the period one or two years?
    Bert
  8. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Bert,
    it's 2 yr return to base warranty with 90 days on the lamp.
    Jeff :rtfm:
  9. Bert Coules
    Bert Coules
    Mar 17, 2002
    2,995
    +119
    Again, thanks very much.
    I did, but I couldn't find any mention of the guarantee period...
    Bert
