Sanyo Z2 cabling
Discussion in 'Projectors, Screens & Video Processors' started by pc99, Dec 1, 2003.
  1. pc99
    pc99
    Feb 28, 2001
    263
    Milton Keynes, United Kingdom
    +3
    I will hopefully soon be taking delivery of a Sanyo Z2. I currently have a cable (buried in the wall which is component video to VGA, for my Toshiba projector.
    I was going to simply cut the VGA connector off the end and connect 3 RCA connectors and use the component input, but does anyone know whether I can simply connect a DVI adaptor to the VGA connector and use that with the Sanyo.
    I assume that this will just give component over DVI, and that the picture quality should be identical either way, unless I upgrade to a DVI output DVD player.
  2. markbro
    markbro
    Sep 25, 2003
    56
    Co. Limerick, Ireland
