Sanyo Z2 and Sky Digibox
Discussion in 'Projectors, Screens & Video Processors' started by Phil White, Nov 15, 2003.
  1. Phil White
    Phil White
    My long awaited Z2 is due to arrive next week to replade mu trusty Tosh MT3!
    I'm going to feed PAL prgressive component from a Sony DVD player (930). For watching TV from SKY I could use my exixting RGB to S Video converter.
    Can I feed RGB from the Scart out on the digibox to the DVI input on the Z2? If so - does anyone know if the leads advertised as being suitable for the Z1 will work?
    Thanks!
  2. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Phil,
    Im hoping a scart to VGA and VGA to DVI will sort tis problem out for me. I have the leads already as soon as I get the Z2 Ill let you know if it works.
  3. Phil White
    Phil White
    Thanks nunew! My Z2 was due in at the dealers yestereday (Friday)although I'm not holding my breath!
    Keene do a RGB Scart to 15 pin male HD male (for Z1) - anyone know if this will work with the Z2?
  4. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    I didnt go for that. I went for the keene with h synchand vertical synch. Could be a £30 mistake, Ill have to wait and see
  5. Phil White
    Phil White
    The Sanyo wiring diagram for the DVI-RGB socket only shows the requirement for horizontal sync in addition to RGB - any one know if this can be picked up from the Sky Scart output without having to invest in a 'Synch Blaster lead'?!! Perhaps from compo video?
  6. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Pin 8 is analogue vertical synch, hence me going for a keene rgb + h and v synch!
