From memory I don't think the Z1 displays the incoming signal info.
As the Z1 has no built-in deinterlacer, it should be easy to see if you are outputting progressive or not. You will see a lot of line twitter on horizontal lines if the signal is interlaced. Very easy to see on a test disc like Avia using the resolution charts.
