W
wixy
Im looking at both of these, the key feature i need being the lens shift.
Key Specs:
Hitachi PJ-TX10
700 ANSI
800:1 contrast
Zoom: Manual, 2.08:1
28.0 dB (26 in quiet mode)
854x480 Pixels
2000 hours lamp
Sanyo PLV-Z1
700 ANSI
800:1 contrast
Zoom: Manual, 1.21:1
28.0 dB
964x544 Pixels
2000 hours lamp
As you can see on paper they seem pretty much the same except for the extra resolution of the sanyo.
The sanyo has a bigger throw (142 cm at 2m compared to 99cm at 2m for hitachi), however the hitachi can zoom to 199cm at 2m as opposed to 171 cm for the sanyo.
And if i throw at 3m (which i can if i move a lot of stuff around) the hitachis zoom gives it an even bigger image size than the sanyo.
So my questions are:
- Is the extra resolution of the sanyo really worth it? (it still loses lines in PAL)
- Will zoom affect picture quality?
- Which do you thing is better?
Cheers.
Key Specs:
Hitachi PJ-TX10
700 ANSI
800:1 contrast
854x480 Pixels
2000 hours lamp
Sanyo PLV-Z1
700 ANSI
800:1 contrast
28.0 dB
964x544 Pixels
2000 hours lamp
Cheers.
